Alternator Pulley
Alexa11:
Look on the Model A web site for supplier named Mikesafordable, just type that on google and it will come up. You can call or place an order on line. The part you want I put on mine also.
Alternator Pulley
Code:A10131A
Price: $32.95
Model Year: 1928 - 1931
UOM: Each
Quantity in Basket: none
High output pulley has a smaller diameter than Standard. Fits any alternator with a .670 shaft size. This gives a 20% faster R.P.M. which allows a charging rate at a lower engine R.P.M.
Enjoy, good luck, Bob0 -
I suggest checking with your local Alternator/Starter Rebuild Shop for a used pully possibly from a truck.....I know they exist because I bought a Hornet that had 12V with a wide pully on the Alternator. Perhaps a Generator pully will fit by reaming.....Not sure...0 -
I ordered the pulley, thanks for the info!0
- 612 Vehicles
