1/2 inch head studs for 308 with 262 head
DavidC
DavidC Senior Contributor
I am planning to convert my head/block over to 1/2 inch studs for the improved clamping. Basically it's part of the 'do everything on my wish list while she's disassembled' plan. The only part number I've found is Caterpillar 3H7927, which Mr. Bennett is credited with on Ken Cate's site. It fits the Clifford Head. Will this work with the 262 head on a 308, or is the 262 taller, and therefore needs a different stud length?
Dale Cooper has bolts, but not studs. I'm looking to go with the questionably more aesthetically pleasing stud arrangement.
Any one with stock or a good part number or source for 1/2 inch studs, please chime in. Thanks.
Dave Carpenter
  • hudsontech
    hudsontech Senior Contributor
    I'm hope your block is already tapped for 1/2"??? I converted 2 308's back-in-the-day and I'm here to tell you I wouldn't do it again. I'd find a machine shop to do the job. Admittedly this was back in the 70's, so perhaps tools have improved since then.
    Those chrome alloy blocks are a b$#@ch to drill out.
    Alex Burr
    Memphis, TN
  • dougson
    dougson Senior Contributor
    I saw a while back about crank or rod studs for the 454 Chevy block will work in a Hudson block. I have Hudson studs and it appears there are two lengths. Don't know why, maybe longer ones are where brackets attach. And I agree that tapping a 7/16" block for 1/2" studs will be a chore. One reason I bought a '56 308 for my resto. project
  • Ol racer
    Ol racer Senior Contributor
    Dougson,
    The guys are right the block can be drilled and tapped by hand but with 21 holes it gets tedious. The best method is have an automotive machine shop tap to ensure threads are accurate otherwise the Cyl head wont slide over the studs.
    Cifford Heads are at least 1/2" Thicker than Hudson.
    New ARP Studs can be obtained from Randy Maas
    or, suggest going to Dorman's Web Site to look up the size need & Part Number then go to an Automotive Store to order.
    Dorman makes hundreds of sizes But most Stores today wont bother to look it up)[/I
  • Little tip for those who don't know, Hudson heads were 2 inches thick when new, exactly 2 in!
  • ski4life65
    ski4life65 Expert Adviser
    About 20 yrs. ago I did it to a 51 block. I think it took about 6 drill bits and a few taps to get the job done. Around the 5th hole, I concluded I had made a huge mistake. I finished, but it wasn't fun. It did look good though.
  • hudsontech
    Got you beat - took me 8 drill bits on the first, and 7 on the 2nd block. I forgot how many taps I busted, but enough to raise the price of the company's stock a few points.
    Alex Burr
    Memphis, TN
    Dave Carpenter
    You are asking for trouble with studs. After you run it a few miles and have to remove the head, good luck. Use bolts and remove with now trouble. My cylinder head has 132,000 miles with bolts, and still no problems. And you all know how I drive my Hudson. Walt.
  • RL Chilton
    Only downside I can see is an aesthetic one. Acorn nuts, which are really attractive on flatheads could not be utilized, unless someone makes an acorn "cap" to fit onto the bolt head.
  • Kdancy
    Kdancy Senior Contributor
    Isn't that pretty!
    What finish did you do your intake with ?
  • RL Chilton
    Hudson308 wrote:
    Like these, Russell? :)
    Attachment not found.
    Yep!! Just like that.
  • DavidC
    Thank you all for the tremendously valuable responses.
    It would appear the consensus is to have professional tap job done, and ask self whether the bling is worth the maintenace fiasco.
    Yes, I am definitely going to have a professional machine shop due the tapping.
    Yes, the look of the acorn nuts was the driving force. What price vanity? Look at that beautiful yellow block! Who can blame me?
    Walt and others, I now fear a future head removal post-stud install. I was planning to use one of Dale Cooper's modern head gaskets, so the adhesion problem would be real. Only reasonable stud option would be to ensure the studs are easily removable, perhaps Allen-drive like some modern studs, and set in plenty of the anti-seize sealants recommended in other forum strings? Will talk with Mr Maas.
    Other option would be to chrome 1/2 inch bolts from Mr. Cooper- not quite as pretty as acorns, but still flashy.
    Thanks again to everyone who replied.
    Dave C
  • Ol racer
    The ARP Studs Randy Maas (maasfh@ntslink.net )sells have Allen Wrench tops for ez to install/remove........
    JC Whitney and others sell chrome Acorn Nuts
  • ratlee2
    ratlee2 Expert Adviser
    What about chrome acorn bolt caps. Still get the look you're after without the hassle. Looks like they offer difference sizes depending on whether you go 1/2" or keep the 7"16" BOLTS. Gotta love the shinny aluminum intakes. One of those is in my future as well.
    -Rich
    http://cgi.ebay.com/ebaymotors/Chrome-Bolt-Toppers-Acorn-caps-Hot-Nut-Covers-METAL_W0QQitemZ260454488264QQcmdZViewItemQQptZMotorcycles_Parts_Accessories
  • TwinH
    TwinH Senior Contributor
    My 49 came to me with a cracked Clifford head that was studded and yes
    it was a pain to get off. After getting the head repaired I got the ARP studs
    that have an allen head recess on the fine thread end. I coated the full
    length of the studs with never seize as part of the problem getting the
    head off was the dissimilar metal corrosion between the studs and aluminum
    head. Haven't had to remove it yet but my thinking is the studs should turn
    right out and the never seize should also stop the water from leaking past
    the threads on the deck. Finished it off with chrome acorn covers on the nuts
    from http://www.thenightprowlers.com/ at like $.60/pc.
  • GrimGreaser
    Oh HELL yes! Consider that idea pilfered. :D Very cool!
  • hoggyrubber
    hoggyrubber Expert Adviser
    yes, i have to say waaay cool. 308 winchester!
  • essexcoupe3131
    essexcoupe3131 Senior Contributor
    That is real classy,
    love the super clean details and the color, what can i say:D
    Mike
  • RL Chilton
    308-
    That's a heck of an idea!! Very cool! Don't be surprised if you see these on someone else's Hudson in the future. "308" on the casing is a super touch.;)
  • RL Chilton
    This sounds like the most reasonable plan, to me. Solid mechanical performance and the "look".
  • DavidC
    Thanks again to all. I now have a solid plan for professionally drilled 1/2 holes, grade 8 bolts, and chrome nut caps. Perfect!
    Dave Carpenter
