52 stepdown front seat adjustment
Abiut 6 to 8 inches, Lee. Pop the seat cushion out and clean and lubricate the tracks/linkage. Also make sure the return springs are on both sides. They hook to the tracks at the front and to a small rectan gular tab with a small hole in it that's welded to the floor pan.0
Thanks for the information Steve. My seat was moving very little maybe an 1" or 2 with great difficulty. I was pretty sure it should move more, without difficulty.
One more item for the 2do list.
Lee O'Dell0 -
And don't forget the seat base hase two sets of holes to mount it. You can gain an extra inch +or- that way. And the factory had spacers to lift the seat up or tilt it also,
Roger0 -
While we're on the subject, my 49 seat has never moved. The lever was missing
when I got it,but I'm not quite sure what else is missing. Does anyone have
an extra lever/shaft/???
When you remove the seat frame, the lever stays with it. It fits into the 1/4 +-" hole in the outside of the left bseat btrak and can be seen in the photo.0
