palnuts
Who knows? The question will be answered if one of em loosens up. Only takes a few minutes, just do it.0
Of course they're necessary - the pal nuts cost under a buck each (I haven't checked the prices lately - but I'm sure it's under a buck).
You got to ask yourself - how much is a new engine gonna cost you if a rod loosens up enough to exit itself thru the side of the block, hmmmmmmm??
As Uncle J says "just do it". Cheap insurance.
Alex Burr
Memphis, TN0 -
I know you are right, I didnt realize my mistake till I looked at one of my dissasembly photos. The oil pan is on and torqed. ARRRGGG! The palnuts never work loose?0
The Commodore wrote:I know you are right, I didnt realize my mistake till I looked at one of my dissasembly photos. The oil pan is on and torqed. ARRRGGG! The palnuts never work loose?
I wouldn't stick my neck out and say they NEVER work loose. There is that fellow named ---- Murphy!!!!:dry:
Let's just say that I was an engineman (fancy name for mechanic) for 17 years in the Coast Guard and I never found a loose one or one that had come unglued, so to speak.
Alex Burr
Memphis, TN0 -
do you happen to know the correct size for a 56 308?0
Same as the bolt it's going on - I can't remember the size of the rod cap bolt. If it's 7/16"-24, for example then whatever the nut size is will be what the pal nut will be.
Alex Burr
Memphis, TN0 -
3/8" unf0
Thank you for your help on this journey.0
- 612 Vehicles
