Looking for a 1953 Jet exhaust manifold and the heat exchanger (single barrel).
brandon i have ione out in my drive way i'll check it out in the morning and let you know what kind of shape it's in0
If its still bolted together and not cracked I advise installing as it is. The chances are if you seperate them one will crack .I have lost several that way that probably would have been good for some time if I had left well enough alone and installed as a unit,
Roger0 -
I will keep that info in mind, thank you Roger. Reminds me of working on Ford Model T exhausts; they have a bad habit of sagging badly if not kept tightened down. You would have loved the jig that my friend designed to straighten those manifolds, lots of fun.0
I will bring one to the National.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
