I think the wide block 308 crankshaft is internally balanced via counter-weights (?), so
Go with 2. Harmonic balancer and flywheel are each balanced separately.0
Every part in a Hudson engine was balanced separately, crank, rods, pistons, valves, cam, bearings, you name it and that is why you can change a crankshaft, and any part, engine to engine and it stays in balance. They were not balanced as a complete unit. Why do you think there are still Hudson engines available? Walt.0
Forgot, the crank was balanced by drilling the counter balancers built on the crank. Walt.0
Walt, shame on u; a crank would be unbalanced by drilling holes into counter-balancers; and that would not be too funny0
You should look at a Hudson crank, that is how Hudson did it. A little drill here and a little drill there. Walt.0
peace & joy to u0
Walt won't steer you wrong. Here's the bottom end of my new/never run surplus 308 showing the grease pencil marks still in place from the factory. Rods may have been select fit also as they are all rubber-stamped 0,1,or 2 on the caps.
TwinH, got any more, where can I get one, I like that. Richie.0
Well Richie,we'll need a Delorean and a flux capacitor first. Then we can head back to JC Whitney in the early 1960's and grab a load of them.
If only we could do that TwinH. Many times I have thought about growing up in the fifties, the absolute best time ever to grow up. Hard working, honest people, and a handshake was a mans word. Sad to see what we have today. Anyway, I love your engine, just keep enjoying it. !! Richie.0
- 182 The Flathead Forum
