1933 Terraplane 8 followed me home
I pulled the radiator tonight, not too bad aside from the "conversion work". You can see fan marks too.
Note the extra spout on the bottom right
I'll break out the torch and see what I can undo I think...
I decided to replace the bearing and complete the cosmetic rebuild of the generator. I glass beaded the parts and they are drying now, hopefully I can reassemble later this week. I'll have it rewound a bit later, bigger fish to fry right now. Pics coming later this week.0 -
Got a box of frame parts today, I'm much closer now:). I can clean up my frame and straighten this out and I'll be good to go. Thanks Ric!
I really can appreciate how the Internet has changed this hobby. Maybe not all for the better, but I have received so much help with parts and information it's unbelievable. I hope posting all these little tidbits proves helpful to others as well.
MATT I BOUGHT A 34/5 FRAME OFF ERIC KIRK IN WINCHESTER VA. A FEW YEARS AGO I HAVE NEVER PICKED IT UP HE WAS TO THIN HIS THINGS OUT AFTER HE HAD HIS STROKE IF YOU CAN USE IT I PAID $100 FOR IT IT'S IN KINGWOOD WVA.0
Paul, Send info. I could get it around Docs meet this year.
Saturday I unsoldered the extra spout from the radiator, and removed the plug from the factory spout. I think I can work with this.
Also picked up a core "72" stamped carburetor from Ebay, per Walt this should be the correct carb for the car.
Both waterpump housings are stripped and ready for final assembly.0 -
Great Job ! You are going fast !0
Got the water jacket ready. Modified a later Hudson 8 unit to resemble the 33T8. I thought it was interesting that the later units were made by Dorman. The later neck is slightly larger, but its a good fit since the radiator repair I'm doing will also require a larger neck so I can put an outer sleeve on it. I hired out the welding
You can see here how rusty the baffle plate in the original one is.
Also blasted and repainted the spark plug wire housing.
Before pic
really lookin' good!0
Very nice! Keep the pictures coming.
great work Matt, esp. with the help you're getting!!!!!!!!!!!!0
Stripped all the junk that has been added over the years from the firewall.
I was planning to clean things up a bit and put the engine in, but the deeper I go, the deeper I go. Since I'm this far, I think I will remove the front fenders so I can properly clean the frame and front suspension. Oh well, I dont want to do it twice.0 -
You're sure doing a great job Matt!0
Thanks Pete -I'm trying and having fun:)
Oh yeah, I also found this rare "Pontiac " hood while cruising Ebay Saturday. It was 25 minutes from my house, now its in my house. Its going to Sam Ramsey to add to his 33T8 parts he's collecting to put a 33T8 convertible back together.
My firewall was bent at some point during the previous upgrade. I have the missing throttle linkage now, but I have to do some bending. As the weather improves, I will start working on my welding skills.
I have to decide if I'm going to weld up the extra holes in the firewall while I have it at this point.
Since the front is this far apart, I decided to go a little further and remove the fenders to clean the frame before I get the engine back.
Heres some excellent body work done in the early 60s.
Under the putty, I thought it was lead at first.
It took some careful trimming to cut the weld without cutting the fender
That's racing red I believe. Apparently back in the day you could brush this stuff on and gain 10mph on the top end
In its past someone painted that red on most of the underside of all the fenders, frame, axles, springs etc. For contrast the brake drums were painted gray and the wheels brushed yellow
. It's all going to be black soon. 0
- 96 Essex Super 6
