Interest for 32/33 T-plane 6/8 "new" water pumps?
Trying to be helpful:32 ET K water pump outlet to radiator has smaller outlet size than 33 ET series outlet.33 ET 8 cyl had 6 impeller vanes.34 & 35 pumps have some interesting variables, carbon seals, lube pressure mechanisms, pulleys.Other variations may exist, but these are from my experience, and in my possession.I have seen seen Chevrolet water pumps with pulleys that seemed identical to 32/33 pulleys.c0
I wonder how many vendors produced these? There seems to be many variations. My pump from a 33 T8 had a three vane impeller, but I can't say that it is original to the engine. Others have told me same the 33 8s had a three vane, but later models had more. The same pump had a steel pulley, but I also have Aluminum pulleys that match. I have two identical cast aluminum pulleys with the same part number, but different size shaft bores. One is correct for my original pump shaft and one is way too small. I suppose there are many small details that make components non interchangeable, but the complete assembly would be. Part of the fun, a new mystery with every part ...0
Interesting article on 3D printing as part of reproducing a water pump casing & impeller
(click on attached page to open)
- 96 Essex Super 6
