1948 hudson Commodore
Welcome aboard!
Easiest is a 48-52 Hudson 8. They are all the same so they will drop in and use any of your parts. Any 48-54 232-262-308 6 cyl will drop in but you'll need more than just a good block. a 55 or 56 308 will go in with a crank spacer, the parts needed for an earlier 6 plus the mounting plates at each end of the block.
Is the original engine beyond reasonable overhaul status? They sure are nice when running right!0
And expensive to rebuild0
Super dave I don't have the engine on the
Nicks thank you for the info.0
- 104 Essex Super 6
