Electronic Ignition
I think I addressed that same ignition back in the beginning. But there has been a couple of these ignition threads lately.
I'm currently running the mopar pickup to trigger my EFI.
Stock distr converted.
Dodge distr converted with lower Hudson shaft.
GM small cap machined for Hudson.
For EFI only.
Charles4d,
Frankvintage: No I did not mis-spoke. My negative post is connected to the frame, or under the engine mount that is connected to the frame. Or does that mean I am grounded postively? I always thought I was negative grounded. I would like to know.....
I think Gramps just mis-spoke. I'll bet he meant "Positive Earth", and yes, they're all Pos grnd, 6V systems 'til the late Hash cars.
F
Hmmmmm. I hope you didn't take that wrong, but 6V Hudsons are all positive ground systems as far as I know. That said, I do have a '51 S-6 that I bought several years ago that was purported to have been a former police car and it was wired as Negative Grnd, presumably to accommodate radio gear. The stock radio won't work (or shouldn't) but I think all else will work as long as the generator is polarized correctly and it may have used a different regulator......I guess I should go look, huh?
It appears you positively have a negative ground system.
F0
- 103 Hudson 1916 - 1929
- 28.5K HUDSON
- 172 The Flathead Forum
- 599 Vehicles
