LED lights load resister
http://www.delcity.net/store/LED-Load-Resistors/p_807671?utm_campaign=Email+Mass+Blast&utm_source=hs_email&utm_medium=email&utm_content=17685561&_hsenc=p2ANqtz-_jEIUp7WlGuaNQ_9lKEorZ8sIci79M9Uw5yDA84a_ib29Q_S-9IV3snv0cJGSMLw6lyRqs8iIuYtjMkMHO7fCRHZ_sUg&_hsmi=17685561
Just got in my e-mail for those interested.
A little humorous when you think about it. The LED uses less current.. great, but then you add a load resistor to USE current.. LOL. They are brighter .
For most flasher units you have to have a given load for the unit to work, hence the resistor. The main advantage of this set-up is the brightness of the LED ,an d the longer life. LED's do not blow like bulbs.Geoff0
Indeed!0
Richard, those look great- plenty of light for a following automobile to have warning.
Now that would be good if the behind-the-bumper lights came on with the brake lights. I could live with that, it's subtle, but effective.0
Couldn't see the bumper LEDs in the daylight; at least you can't where I live !!! But click on the Vimeo above and see the third brake light do its thing. You also can't see the other 900 LEDs I have under the car in the daylight !!
) 0
- 104 Essex Super 6
