1951 dodge engine Id
Mark
How do I find out what is the cid of this engine
engine is not original 25 inches long0
The long blocks were either 251 or 265 cu in. . The p15-d24 board is devoted to mopar. Lots of info. over there. Hope this helps. LHud0
Mark, Not sure you're at the right place. You're looking for the engine ID to a 51 Dodge? OK well this is the Hudson forum. Likely not going to be of much help. Maybe the Mopar forum might be better for you. If you still think you have a Hudson engine then take a picture of it and post it.0
The Flathead Forum is a left-over from the days when this was the Classiccar Forum, and had categories for many different marques. So I think it's not unusual that we'd have someone occasionally posting about a Ford, Dodge, or whatever, under this particular category.
- 105 Essex Super 6
