Pertronix 1362p
Hi, good to be here.I have a 54 Hudson Hornet that my dad,a former Hudson mechanic, bought in 1974 with 11,000 miles when I was 17 years old, the paint and interior are the only things that aren't original. I'm joining this forum to learn more about my car and hopefully get help .
Welcome. Your Hudson looks very nice.
Thanks it just turned over70000 miles0
Welcome on board!
We have plenty of advice to offer.
Some of it is actually helpful!
70,000 miles! That's awesome. Please post pics when you get a chance. I'm sure you will be able to find all of the help that you need. If you can't find it here, someone can always point you the right direction. Welcome to the Open Forum.0
Byron,Where are you located so that we can have the local Hudson Chapter get in touch with you.John Forkner0
Wyoming up against the Absaroka range0
Do you need more info for the local chapter to find me? Computer illiterate.0
I installed the third pertronix module. If this one goes bad I will change back to points. My question is,will the pertronix 1.5 coil work with points?0
The Pertronix Flamethrower coil will work with points but eventually burn the contact surfaces because of the higher energy passing over them. You are better off installing the stock coil with points!
Thanks Ivarsweden0
- 104 Essex Super 6
