Dimensions of rear spindle 1940
3/4'' is correct, the thread is finer than a standard UNF thread.0
3/4-20 Extra Fine NEF0
I got mine from Rock Auto - look for spindle nut for 56 Olds
Thanks guys, I appreciate this info. Uncle Josh, I need to repair the threads on the spindle and I am trying to find a thread chaser to fit. I have been speaking with Thread Tool Supply; I will ask if they have a thread chaser of that size.
You may be able to dress them with a thread file
https://www.mcmaster.com/#thread-repair-files/=186pcxa
If the thread damage is severe and its hard to pick up the starting point on the thread, you may be better of with a 2 piece thread restoration die, you clamp the die onto the good thread and wind it off across the damaged thread. These were quite common once but the only seller I can find with a quick google is these guys https://www.jmeinnovations.com
A good old fashioned 20 tpi thread file may do the trick http://www.webbikeworld.com/motorcycle-tools/thread-file/
Or you can DIY your own split die. Buy a 3/4" x 20tpi hex die, cut it in half with a 1mm cutoff wheel and mount it on the good threads. A socket will hold the 2 halves together and give you a means of winding the die. Oil the threads first.0
- 86 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 592 Vehicles
