Need 4 to 5 more orders for the new 2x2 manifold project.
Just got back in town. I will call Larry to give him my CC info
Don
We have 7 need 2 more!0
I know where a 2x2 intake is very near me . Pardon my newbieness ... are they really that hard to find ?0
You may be thinking of the Edmunds 2x2 that were made in the 50s. That manifold looks great but does not perform particularly well. What we are trying to do is have Clifford Performance make a totally new improved flow manifold that will use 2 Weber down draft 2bbl carbs.0
Ooooooh yeah I found a stock Hudson 2x 2 intake off a 53 hornet0
Sorry I don't think that is a 2x2, it is most likely a cast iron Twin H, 2 x 1bbs.0
Gotcha , that’s why I apologized for my newbieness before haha0
What engine is the 2x2 manifold your doing this group buy for ?0
It would work for the 232, 262 or 308. However it is jetted for the 308 and would require the carbs to be jetted properly for the 262 or 232. If you have questions you can call Larry at Clifford Phone: 951-471-1161.
website: http://www.cliffordperformance.net
Is it your understanding that the carbs could/would be jetted for the application from Clifford? I can of course call and ask, just wondering if you knew. The 47 pickup I just bought has a 232 installed from some PO in the past. I think the Clifford dual carb setup would be a nice addition. Brad
It is my understanding that it can be done, but I would defer to Larry at Clifford to make sure.0
Left message for them - do you know what the cost is0
Merry Christmas everyone, been busy with work but thought I’d see if others might be interested in this.0
I talked to Larry this morning and he has a total of 6 commitments and needs 9. So if you are interested in getting this off the ground contact him at your earliest convenience. There were a couple of you guys that wanted 2 so make sure Larry has that correct.Phone: 951-471-1161E-mail:larry@cliffordperformance.com0
If it helps get this moving, I will commit to two instead of one.
Don
Don let Larry know. It would put us at 7 so we would need 2 more to kick it off. Larry indicated he would probably run 20 to 30 manifolds if the project gets rolling.0
Dan, have you posted this on the other forum? Maybe even put an ad in the WTN to get it out there as much as possible.0
I have posted on the HET forum, but have not done anything with WTN yet.0
Has there been any updates on this?? If my math is correct, you only need 1 more commitment??0
Yes one more. I will check with Larry tomorrow.0
Don't tempt me! Is this for the whole kit, including carbs and headers? Or just the manifold?
It is the carbs and manifold, no headers in the kit. Here is a similar setup:
https://www.shop.cliffordperformance.net/Chevy-235-261-Twin-38-Weber-Fuel-Delivery-System-08-7001-C235-261.htm
The kits with headers look to be about $300 more. I will ask Larry if he would do a similar setup for the H6.0 -
Kit will be available with headers if desired.
How many commitments do we have so far?
From what I was told by Larry 7 or 8. It depends if all three that take two are serious. I am pretty sure there are 7. I will be submitting something for the WTN today to see if there is more interest.0
If you want one can you PM me to make sure my list and Larry's are the same? We may have more than I counted.0
Here is another update from Larry I was unaware of. You will need to use headers for this setup as the water jacket will interfere with the stock exhaust manifold. So if you do not have headers on your Hudson you will need to spend the extra $300 for the set.0
So there's a water jacket through the headers? How does that get "piped in?" Through the heater hose line?0
No a water jacket on the intake0
- 104 Essex Super 6
