My Hudson Hornet -52 project,
New brake brackets is ready now, next black powercoating paint and then i go next job...?
Thank’sKustomKreeps said:nice work0 -
Very nice! Keep the pictures coming.
NICE!0
New intake manifold and mustang tank with Tank’s systems.
coming along nicely.
I looked at using a tang tank but it was a tad to long for my application due to where I had my exhaust hangers and stuff. So i just fabed one up using the mustang tank as inspiration.
So filler will be in the trunk/boot or will you make a hole for it above or behind the number plate?0 -
Tank filler comes inside trunk. Mustang tank are be now all place left, maybe my exhaust pipe convenience this leftover area.KustomKreeps said:coming along nicely.
Fenders comes back to home!
Ls looking very minimal this engine house.0 -
Looking good!0
Exhaust .... narrow location doing that, but now is it ready.
I do hope that is not a copper brake line. Pure copper lines will not stand up to the pressure. You need steel or the Copper Nickle alloyed lines. Other than that good job.
Jay
I use stainless for all my brake lines anymore. I bought a special flaring tool and it works great. I hand bend them and use a bender sometimes, use a coat hanger or other wire to make my patterns.0
I am in the process of installing a 500ci Cadillac in my '49 Hudson and would really appreciate if you could show more of how you routed your exhaust from the engine on back. I don't want mine visible from the sideview and it seems like a challenge.
Your work looks great, good luck!
Thanks0 -
It is copper/ nickle alloyed lines, here in Finland sell only that brake pipes. Thanks you attention?Jay G said:I do hope that is not a copper brake line. Pure copper lines will not stand up to the pressure. You need steel or the Copper Nickle alloyed lines. Other than that good job.
Jay
airbrushguy said:I am in the process of installing a 500ci Cadillac in my '49 Hudson and would really appreciate if you could show more of how you routed your exhaust from the engine on back. I don't want mine visible from the sideview and it seems like a challenge.
Thanks
Only Way do this exhaust without big body changes. I made this about two weeks after my dailyworks.0 -
vesaku, Hi, Im new here but starting to do a ls1 swap into a hornet as well. found this thread while searching. not much info out there on a swap like this. i love the challenge.
I was wondering if you had any more pics of the rack and pinion set up without the engine installed? also if you have any part numbers for the rack and steering parts you used?
thank you0 -
saon said:vesaku, Hi, Im new here but starting to do a ls1 swap into a hornet as well. found this thread while searching. not much info out there on a swap like this. i love the challenge.
thank you
Intake manifolds
, flowers time.
Vesaku, Great Work!!! I see you are retaining the stock front suspension components. I have a 1951 Hornet with a completely rebuilt stock front suspension with after market power steering. When I had the front end aligned we found out there is very limited adjustment for caster and camber. The caster was 0 degrees for left and 1/2 degree for the right, had to set the total caster at 0 degrees to be balanced. The camber was able to obtain 1 degree for each side. Toe in had ample adjustment range.
My results were very disappointing, driving on any curved road with any small dip or bump immediately throws me into the next lane with no warning. Constant wheel adjustment above 60 MPH is a scare and a chore to drive. This is with modern radial tires.
I was not looking for a modern car driving experience but 1951 engineering was not what I wanted. I should have spent the rebuild money on a "Fat Man" front clip, I would be money ahead and a lot happier.
I hope you can achieve adequate front end adjustment and have a great driving experience, this car is deserving of a good road driving experience. Keep us posted on your project.0 -
.....0
TwinSupercharged said:Vesaku, Great Work!!! I see you are retaining the stock front suspension components. I have a 1951 Hornet with a completely rebuilt stock front suspension with after market power steering. When I had the front end aligned we found out there is very limited adjustment for caster and camber. The caster was 0 degrees for left and 1/2 degree for the right, had to set the total caster at 0 degrees to be balanced. The camber was able to obtain 1 degree for each side. Toe in had ample adjustment range.
I hope you can achieve adequate front end adjustment and have a great driving experience, this car is deserving of a good road driving experience. Keep us posted on your project.I DON'T KNOW HOW THIS FEELS DRIVE BUT IT SEES THEN. Maybe that air suspension will compensate for some of the deficiencies. THANK YOU FOR YOUR INTEREST IN MY PROJECT0 -
Suspension powerpoint is now ready. 0 -
New pic! ^^^^^^^0
Vesa, all I have to say is WOW ! My '53 is almost ready to drive but will never look that good.0
