Looking for passenger side cowl light bracket 29 Essex
oldtoys
As the title says I'm looking for the cowl light bracket for the passenger side for a 1929 Essex.
You may want to check eBay. There have been some 28 Essex cowl light and brackets on there for some time. They may what you need. I have found there are many parts that interchange on either side of the year I am looking for.
Jay
29 are one year only. Do you need right or left, as referenced from the driver's seat? Passenger side can vary, depending on what country you live in.0
Need right side as referenced from the driver's seat.
On kijiji in London area Ontario Canada there is a pair for sale. Type in Essex and go through. They will show up. Brackets and lights. 28/29 not sure look right0
What is different about 28 or 9 just wondering0
'28 are brass with screws through, '29 are smaller curved die-cast with studs.0
Ted, Checked KIJIJI. Those are for a different year. Very different than mine. Thanks for the suggestion.
If you find two let me know. Im looking for exact same. Passenger side cowl light bracket. 1929 Essex0
