Guide Fog lamp
It Will Be Hard To Find This Item. Unless You Come Up With New Old Stock, They Havent Made These For 50 Years. What Is The Diameter Of Lens??? You Can Buy The Modern Two Wire Connector Sealed Beam Lens To Replace Yours0
They are 5inch Lens. I was thinking I would get two wire and just rewire the connectors in the lamps. Thought I should check before I did for anyone knowing a supplier. Thinking I am out of luck for these type.0
- 596 "How To" - Skills, mechanical and other wise
