Door upholstery clips
fliptop
What is a good replacement clip to use on the door upholstery backing?
JC
I've used VW Beetle clips before, pretty similar0
As i am in Australia I have used trim clips off a 1969 holden. Have a look on ebay im sure they are probably a generic GM clip.0
A good source for upholstery clips is Restoration Specialties.0
I need the clips for a 53 Hornet. Thanks all for your suggestions.JC0
These are the clips that i spoke about earlier
https://www.ebay.com.au/itm/141954103838#:~:text=10 PACK DOOR TRIM METAL FASTENING CLIPS for HOLDEN DOOR TRIMS FX to WB (TNSAC82)
Have you used these clips. It is hard to tell from the picture what the dimensions are on the clips. Also they do not post to the US. Do you have a local source?ThanksJC0
There is a listing on EBAY for VW Beetle door panel clips that look like what is pictured above. They're $12.00 for a bag of 50, and the photos show the clips laying on a tape measure.0
These look good, thank all of you for providing this info. I will go ahead and order a bag.JC0
Please let us know how it turns out.0
I did my search as "1963 VW Beetle door panel clips". I found them as low as $9.oo for a bag of 56 pieces, from a VW parts specialty shop. That's how many it takes to do front and rear on a beetle.fliptop said:These look good, thank all of you for providing this info. I will go ahead and order a bag.JC0 -
yes VW clips look exactly the same
The ones stevepet has pictured above I got 2 years ago from a supplier here in Australia called "Rare Spares". "Rare Spares" were the original suppliers of parts for Aussie Holden cars. They supply worldwide now and I'm sure would have a US stockist.
Dalma. Melbourne, Australia0 -
Hi Dalma
Whereabouts in Melb are you. Enjoying your freedom?0 -
Didn't find exactly the clips 54Coupe was referring to. What about these? https://www.ebay.com/itm/112790101917?epid=671986398&hash=item1a42d05f9d:g:O2QAAOSw6JlfdlHz0
That's the same clip... The lower price I found wasn't on EBAY, but a specialized vendor of VW parts.54Hollywood said:Didn't find exactly the clips 54Coupe was referring to. What about these? https://www.ebay.com/itm/112790101917?epid=671986398&hash=item1a42d05f9d:g:O2QAAOSw6JlfdlHz0 -
Thanks.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
