Roof Decking Repair and Water Pump, other solutions
Careful with the aggressive polishes. The plating is thin. Suggest using Simichrome or similar polish tga0
Toddh said:Careful with the aggressive polishes. The plating is thin. Suggest using Simichrome or similar polish tga0
If they are the original headlights, the buckets are chrome plated.0
While your doing your headlight buckets, consider polishing the reflectors. I use dry powdered lampblack with a piece of cotton velvet. as it’s the best polishing for silvered mirror surfaces. Do use anything more aggressive than that.0
Toddh said:While your doing your headlight buckets, consider polishing the reflectors. I use dry powdered lampblack with a piece of cotton velvet. as it’s the best polishing for silvered mirror surfaces. Do use anything more aggressive than that.I had planned to get some things done today but it turned out to be a very busy day and had to go to work early. Hopefully I’ll get to get some things done tomorrow and Friday!0
Old Fogey UK said:DON'T use Barkeepers Friend on chrome ! Use a proper chrome polish.
Don't use polish at all on the reflectors. I don't know what lamp black is, I lightly rub my reflectors with a piece of dry very soft chamois leather using no pressure.
I will email you privately on the procedure for removing and installing headlight lenses - it's a very tricky job !0 -
I will email you privately on the procedure for removing and installing headlight lenses - it's a very tricky job !Hope this helps0 -
Just wanted to get out and get started this morning after taking a nap from work last night.Started using a oddly prefect sized screwdriver and began scraping the old black sealant out of the channel…boy does it turn into a nice fine particulate in the air
gets everywhere and in eyes!
I felt this was the perfect opportunity to pull out my vintage safety glasses haha.This is very tedious stuff, so went and grabbed one of my Merchant Service pipes that’s been sitting on the rack, grabbed some LJ Peretti and went to work! Might take a while lol0 -
Old Fogey UK said:Toddh said:Old Fogey UK said:DON'T use Barkeepers Friend on chrome ! Use a proper chrome polish.
Guardian1fox2 said:Old Fogey UK said:DON'T use Barkeepers Friend on chrome ! Use a proper chrome polish.
I will email you privately on the procedure for removing and installing headlight lenses - it's a very tricky job !That might have been my suggestion you are referring to.I did clearly indicate that it is not used as an abrasive along with elbow grease but rather to make a paste of it and gently apply more as it evaporates. The active ingredient is Oxalic acid which is also used in wood cleaner/bleach. If you want to avoid the abrasive BKF.0 -
Okay guys! So I made some progress today and removed the sealant in the channel. Used this little screwdriver and it worked wonders, along with this little tool idk what it was but it had a bladed hook on one end and a point on other. The trim looks to be in great shape while some spots rusty.The racks are so small and there’s so many! I believe that’s gonna be a paint in the ass to remove. I got some great advice from Eric Harrtz, along with some articles he sent to assist with info. Really nice of him to talk things over with me! Here’s some progress pics:0
rusty_apache said:Guardian1fox2 said:Old Fogey UK said:DON'T use Barkeepers Friend on chrome ! Use a proper chrome polish.
I am interested in the repair/restoration of your roof top. I have a 32 Essex Terraplane coupe roof which I want to recover with marine grade vinyl. This car is not an antique car true restoration but a modified hot rod. Purist forgive me but the car was a bare chopped top body shell when I got it. I did not cut it up !
I have scored the internet for information on installation information for these soft padded tops common to early cars before the mid 30's . Most info comes from the Fords. From what I have found is that the metal trim you are referring to is called a tack strip . At the bottom inside of the tack strip is wood which the tacks are driven into and a sealer is placed over the tack heads which you dug out with a screw driver. The tack strip is fastened to the roof insert channel with with large copper ( 12 GA) wire staples through the tack strip down through the slotted holes in the roof then folded over underneath the body sheet metal. The only reason I know this is my body came with some of the tack strip remaining. The tack strips replacements are unattainable I will try to post pictures latter. If you are Interested in the wire-on welting ( hidem ) there is a You Tube video on the Labaron and Bonney channel ( company gone out business as you probably know by now). I have not decided on using the wire-on hidem or the other regular hidem for my installation. i will probably use chicken wire support ( the Ford way ) instead of muslin cloth. I am a long ways from doing the job.
I thank you for all the pictures you have taken of you roof and urge you to continue as we have no other real written information pertaining to these tops that I am aware of.
If you could provide pictures of the wood crossbows/structure when all top materials are removed would be greatly appreciated. I have no wood structure left in my body for a visual reference. Good luck. I think we are both up too and can handle these roof challenges.
32huson said:I am interested in the repair/restoration of your roof top. I have a 32 Essex Terraplane coupe roof which I want to recover with marine grade vinyl. This car is not an antique car true restoration but a modified hot rod. Purist forgive me but the car was a bare chopped top body shell when I got it. I did not cut it up !
I will also be updating this thread as well!0 -
Also, there may not be “correct” replacements but you can get C-channel aluminum and bend it that will work the same I’m sure. Mine isn’t stapled from what I can tell so far just tacked with super small tacks. You’ll see in video.0
Yes I have read about the aluminum and challenges in bending it. I think I will be making a tack strip from layers of ABS plastic glued and cut to shape as I had seen in a thread /post on the Hamb. I not trying to be authentic just interested in getting the job done economically and within my skills. Always open to suggestions though.0
Tack strip picture0
32huson said:Tack strip picture0
Really ?? I posted 4 pics . I can see them right above your last comment.0
I think your pulling my leg Tim . LOL.0
Okay so I got the rear seat out, vacuumed up a bunch of dirt etc. i noticed the floor and bolts have a slight surface rust so I sprayed some kroil on the bolt heads just for preventative maint. How do I access the sending unit for gas tank? Is it under that oval shaped cover in the very back that’s held in place with two screws? After I check that out and install the seat belts, I was thinking of taking something to rough up the floor and coat with some por 15 just to be safe, the underside has already been cleaned and painted…looks brand new under the car lol I just wanna make sure the inside stays the same. Here are pics. Sorry for the weird wet spots on the bolts that’s the Kroil I barely put any but you can see how it penetrates!Not sure what the cloth cover down there is for.0
Also, cleaned up 2 of the 4 ash trays from interior. The front two were empty but the back one still had 1930s ash in them along with old match sticks! Lol
I was too lazy to grab the buffer and bring it into the house cause it’s too cold lol so I just use some old mothers chrome polish I had laying around, 0000 steel wool and a rag. Not my ideal materials but it worked for now. I think when I get back from church tomorrow I’ll pull out the variable buffer and get to work. I also ordered some Quick-Glo…there out of my state of Louisiana so I figured I’d try it. Saw it on Jay Lenos garage…ehh blew money on worst stuff lol here’s some pics. I also coated the lids in paste wax.
Tack strip and roof pictures. The large holes are for the wood cross bows fasteners. The smaller holes for the tack strip hold down staples0
32huson said:Tack strip and roof pictures. The large holes are for the wood cross bows fasteners. The smaller holes for the tack strip hold down staples0
I am misleading you by calling them staples. They are pieces of u shaped wire inserted through the tack strip and roof with the ends folded over. That is what I removed from mine. Can you post pictures of the info from the manual ?0
32huson said:I am misleading you by calling them staples. They are pieces of u shaped wire inserted through the tack strip and roof with the ends folded over. That is what I removed from mine. Can you post pictures of the info from the manual ?First is the Hudson Maint manual though.0
Guy came by finally to take a look at the roof paint. he figured once I got the top off, it could go to him before it’s reinstalled, for him to paint. He’s also wanting to paint the doors, and the front portion under and around windshield I guess the cowl? Not sure what you call that. Told me that would be the time to remove windshield, get new seal for it and get trim cleaned up. $900 total…does that sound like a good price? It’s basically a “side job” for him. He does modern cars for a living and normally doesn’t take side jobs but when he saw what it was he wants to do it. He told me all about the primer he saw called it “Lacquer primer” and reinforced the fact it was done long time ago but looks to be perfect and in great shape. The price involved me removing the door handles and such to help with price.Do y’all think this is a good price? I’m not familiar with this. I’ve never had a car painted or anything. He said he needs it to be a good weather weekend, for him to get started and prep, and it would most likely take a couple weeks.Seems to be coming along, maybe the stars are aligning! Lol I think it’ll at least get me by until I can afford a complete paint job. He said complete I would possibly be looking at $6K and that’s with me doing disassembly.Got a tool made today to remove tacks easily. Hard to do anything when I’m working days, so may not get to make much progress until Friday.0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
- 605 Vehicles
