To What Mark Should I Time The Ignition ?
Old Fogey UK
I'm running my '34 254 cu in Eight on 97 Octane (E5) fuel as it doesn't like the British 95 Octane (E10).
I'm using Champion RJ12C plugs because the car tends to get used on short runs and I was told "hot" plugs were better for that sort of use.
The engine has been tuned to Top Dead Centre but I think that may be wrong because acceleration is now a bit rough (as though the choke is out, but it isn't) and the plugs are quickly getting sooty.
Any suggestions, please, on whether I should try re-timing and to what mark on the flywheel ?
It will be necessary to check your gasoline air ratio. Since you're talking about black candles. Can be a carbu setting because your CO may be too high. For this; I have a gas analyzer at home.
https://www.ebay-kleinanzeigen.de/s-anzeige/motor-test-geraet-mt-5009/2189909498-223-8076
It is the same as mine. With strobe lamp......
JACK356 said:It will be necessary to check your gasoline air ratio. Since you're talking about black candles. Can be a carbu setting because your CO may be too high. For this; I have a gas analyzer at home.
It's nice to hear from you again.
How is the restoration coming along ?0 -
Merci.Ca advances; but not easy to communicate because, knowing only to speak French. I put new photos.0
- 86 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 593 Vehicles
