Hudson engine hoist
contact kerry0
Here are the blueprints you can take to a machine shop-
Thanks! The drawing notes say Super 6 but I thought it was for the straight 8? Do you know if it fits the 8?Jeremiah36 H80
If I remember right, the 8 has a different bolt measurement. I would check with Dr. Doug for confirmation. Hope someone makes these, again. If not, let me know, as I have a new shop/welders that I work with and they might be persuaded to make a run if there is enough interest.
The blueprints were actually drawn by my father, who grew up on a drafting table. Sadly, he passed away last year.
We did make the prototype off of those drawings and it works flawlessly. It is an exact copy of the lifts they used at the Hudson plant.0 -
Ditto.0
Russell, sorry to hear about your father. Those drawings looked fantastic! I'll measure my 8 this weekend and see if it would fit. Doug Wildrick has a video of installing a splasher 8 into a stepdown using a similar bracket.
The 8’s had an entirely different head bolt pattern.0
54 is correct there is no commonality between the H8 and I6 narrow or wide block.0
The two 9/16 holes are attached to head studs?
The four radii curves are cut to fit around spark plugs?
What’s the 1 & 1/16 center hole for?
Jeremiah
I combined the 4 blueprint scans posted above into one image and cleaned the image up a bit. Might make it easier to read for some.
Tom
It is possible to overthink these things. Quick and easy is 4 pieces of 2" x 2" x 1/8" steel angle about 2" long. Drill one hole in each leg. Bolt one leg to the engine, put a lifting shackle on the other leg. Done.
Yes. But then you wouldn't have an exact replica of the lifts used at the factory, would you?
1 -
Here's what the actual one looks like.
1 -
FWIW the weight of a H8 with clutch and flywheel but no gear box is 260 kg - 570 lb.
Lifting brackets are holding up well. 😉
1 -
Thanks Bob! Nice looking engine too!
So you had to remove 4 nuts on the head studs to attach the brackets, doesn’t that affect the hold down on the head? Do you have to loosen and re-torque the whole head after installing it back on the frame or is the head not torqued down until you put it back in the frame?
Jeremiah
I put the lifting eyes on 1 at a time and retorqued the nut. When I'm done I might slacken all the head bolts and retorque them, but I'm not too concerned, these engines are very low tech and rugged.
- 81 Hudson 8
