Rear Fenders
Anyone have a pair of rear fenders for a 1929 Essex Challenger? I'm in the midwest.
Ken
  • Hans
    Hans Senior Contributor
    To be helpful, what body style do you have?
    fenders for the coupe/ roadster / 2 door & short 4 door / and the larger ( longer body ) 4 door are all different.
  • Hans
  • I have a 4 door Challenger Sedan
  • Hans
    Good, a 4 door body
    Now the two 4 door bodies are different.
    The regular 4 door body has two windows one in each door on one side of car. The fenders are a little wider at top of fender.
    `The longer 4 door body has a third window on side, in rear quarter. The fenders are a little narrower at top of fender. In addition, the ribbed panel covering gas tank on this longer body appears shorter and there is about 4 inches from spare tire to body.
    the larger body narrower fender could be modified to work on the other body. to keep wheel opening vertical.
    I hope this helps you
    Hans
  • In that case, I have a regular 4 door body.
  • Hans
    Based upon your description, then the 2 door and 4 door body, car fenders are likely the most easily found.
    There has been a person selling various Essex 2 parts on Ebay and I think Facebook.
    Good fortune to you
    Just noticed add for 29 Essex part for sale
    Hudson Essex Terraplane - Buy/Sell/Trade | Facebook
    has rear fenders
  • Qtband
    Qtband Member
    The guy on FB has a 2 door.
  • Hans
    the regular 4 door and 2 door rear fenders are the same.
  • Qtband
    Qtband Member
    I can't find that Facebook post. Maybe he took it down????
  • The two door he is referring to is called a coach.
