Rear Fenders
Anyone have a pair of rear fenders for a 1929 Essex Challenger? I'm in the midwest.
Ken
To be helpful, what body style do you have?
fenders for the coupe/ roadster / 2 door & short 4 door / and the larger ( longer body ) 4 door are all different.
I have a 4 door Challenger Sedan
Good, a 4 door body
Now the two 4 door bodies are different.
The regular 4 door body has two windows one in each door on one side of car. The fenders are a little wider at top of fender.
`The longer 4 door body has a third window on side, in rear quarter. The fenders are a little narrower at top of fender. In addition, the ribbed panel covering gas tank on this longer body appears shorter and there is about 4 inches from spare tire to body.
the larger body narrower fender could be modified to work on the other body. to keep wheel opening vertical.
I hope this helps you
Hans
In that case, I have a regular 4 door body.
Based upon your description, then the 2 door and 4 door body, car fenders are likely the most easily found.
There has been a person selling various Essex 2 parts on Ebay and I think Facebook.
Good fortune to you
Just noticed add for 29 Essex part for sale
Hudson Essex Terraplane - Buy/Sell/Trade | Facebook
has rear fenders
The guy on FB has a 2 door.
the regular 4 door and 2 door rear fenders are the same.
I can't find that Facebook post. Maybe he took it down????
The two door he is referring to is called a coach.
Will that fit my Challenger Sedan?
- 112 Hudson 1916 - 1929
