Has anyone come up with a fix to repair the spring in the 1933 Essex windshield push out /latch mech
tigermoth
Has anyone figured out a method to repair the spring in the 1933 Essex windshield push out /latch mechanism? It may have been used on the 1932 models as well.
thank you.
regards, Tom
The spring attaches here. Is this supposed to turn as the latch is moved to open or close the windshield. I would think it should.
regards, Tom
2 more pics. Same question, does this rotate as the latch handle is lifted?
thank you
regards, Tom
It appears this mechanism was chromed without being disassembled. Shops do that?
So if that piece is supposed to swivel, perhaps that would explain why it doesn’t.
regards, Tom
- 596 "How To" - Skills, mechanical and other wise
