Reconditioning a cam and lifters
blondwookie
I know this topic has been possibly been beat to death.
I'm planning to have my 55, 742 camshaft and hydraulic lifters reconditioned by Delta Camshaft in Tacoma Washington. Has anyone ever done this before?
Thanks in advance, Wookie
To let everyone know in advance, I'm using Jack Clifford intake and headers on my engine. This is why I'm using hydraulic lifters in my engine. I got a good used set of hydraulic lifters from Al in Arizona0
I had my hydraulic lifters redone by Mizpah https://mizpahprecision.com when getting my engine back together. Original cam and 1 lifter were shot in my transplant engine. Tracked down a decent cam and a couple 'new' lifters (for a bakers dozen, just in case...) so far, so good after 5 years...0
I twisted off one of my lifter adjusting bolts on my 1939, 212 six while trying to adjust the valves. Is there any way possible to replace that lifter without pulling the whole engine. If there is a trick to removing the adjuster bolt (stud) that is broken off flush with the top of the lifter body? That would really simplify things.
Not really partner. Lifters come in from the bottom of the engine with the camshaft out of the way
Not so! Only step down and Jet have to take out from underneath. All others come out from the top.
