Center antenna for 48
Most of the major systems are good, and the car is on the road!
http://moltar.chrishull.com/pics/Hudson24Sept2006/frontwithvisor.jpg
The center antanna wasn't making good contact with the radio, so I finally got it apart. Now that it's apart, of course I'm wanting to replace the weather seal. The plastic roof lining interface was damaged when I took the antenna off. Not really enough room to get a 1/2 inch deep socket up in there without hurting the plastic unfortunately. Some of the chrome is kind of shot too.
Does anyone make a nice looking replacement antenna assembly, or some of the plastic parts for an original setup?
Thanks;
-Chris
Thanks;
-Chris
Contact Joe Stinnett in FL. He has repro replacement parts.0
You have to use a thinwall deep socket for the nut inside the plastic housing. I tried several before I borrowed one from a Hudson friend.
Bob0 -
K GAP HAS THE RUBBER BASE GASKET. LOANED AN ORIGINAL TO p kALE LYERS AGO FOR THE MOLD. BILL ALBRIGHT0
- 184 The Flathead Forum
