6 volt headlight amperage?
Jim, I'd use a 20A fuse. That'll handle the normal current comfortably, but will blow quickly in the event of a short to ground.0
I have a dual headlight relay....in fact two, one one each hudson and they came with 30 amp fuses built into the relay. look under the cover you may already have a fuse or two.
Jay0 -
Thanks for the advice. My relay brand is a Dur-A-Bill, if that means anything to anyone.
Jim G.0
- 184 The Flathead Forum
