need rear motor mounts, 55 Hash
I need the rear motor mounts for a 55 Hash Hydra-matic, the ones that go into the bell housing. Bill A tried to help me but all he had were step down mounts and they don't have long enough bolts to go through the bell housing. On the Hash there is a long bolt in each mount the threads into the bell housing, the step downs have smaller diameter studs that aren't long enough. The trans is being rebuilt now, what a mess but luckily Fred has rounded up all the necessary parts except for the rear mounts. Who sells these things?
Harry
Harry
I think you have to contact Paul Schuster. He is PAULARGETYPE on the board here. He is the 55-57 hudson guru. I think he either rebuilds the mounts, or has a source that can recondition the originals. I do not know of any other source.0
by the way this is the hornet 6 w hydro setup, BILL ALBRIGHT0
that might change what Paul can help with. I think he is more in line with the packard v8's.... good point bill.0
You might want to contact Steele Rubber Products. They have a rear trans mount for $44.40. They also do revulcanizing.0
Hi I Do Have Rear Mounts For Your Car They Are The Same As The V8's There $75 Each And You Need 20
Bill;
thanks for putting that in, I always forget something.
Harry0 -
Paul;
I need them, how do I get them from you?
Harry0 -
Paul;
I'll e-mail my address to you as soon as this system will let me. It seems I can only send you one e-mail every 1800 seconds and I still have 1300 seconds to go before I can send another e-mail. Thanks for your help, try to stay cool.
Harry0 -
Call Lester Harris at (775) 267-25590
- 120 Hudson 1916 - 1929
- 612 Vehicles
