Electric fuel pump suggestions
You can use a generic 12v fuel pump. Check with your local NAPA or other parts supplier. Also, you might find one in a hot rod or racing parts catalog, Summit, for example.
An electric fuel pump pushes, does not pull or lift well. I made the mistake of installing one under the hood, I should have installed it in the rear, close to the tank, and as low as possible.0 -
Used one from JC Whitney and has work well Want a low output (3-5 psi) for hudson Carbs0
billn34 wrote:You can use a generic 12v fuel pump. Check with your local NAPA or other parts supplier. Also, you might find one in a hot rod or racing parts catalog, Summit, for example.
Am I correct in assumming that they also make 6 volt electric fuel pumps? Niels0 -
Mine is a 6v model, which I bought from NAPA 15 or more years ago. Your parts house would probably be the place to look for one.
Good point above about using a low pressure pump.0 -
Walbro makes several bellows type fuel pumps. I ran a 6V until converting to 12v. Have not had to install a new one since. One of their pumps is adjustable, down to 1,75 psi, if I recall correctly. JC Whitney sells the higher pressure (4+ psi), non adjustable 12V, as well as the lower pressure 6V pups for under $ 40.00.
Old numbers have been changed for both 6V and 12 V. NAPA does not stock Walbro fuel pumps, here at least... Here's a website . Click on bellows in the left side menu.
W
http://www.autoperformanceengineering.com/0
- 86 Hudson 1916 - 1929
- 11 Upcoming Events
- 75 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 593 Vehicles
