Water pumps
I am in the process of increasing the water pump flow in a 308 modified engine. (Turbo-charged )
Has anyone tried to do this before?
Like using a different impeller? (more blades ? )
other types of pumps ?
If so, please list the modifications you have done and if it helps in cooling the 308 at high speeds.
Hudsonly , Rudy.
Hudsonly , Rudy.
Is the engine running and you are noticing a heat problem?
Or, are you trying to avoid one beforehand?
I don't know how you have it setup. Have you checked your individual exhaust port temperatures? What type of fuel delivery system are you running?
I have been told that forced induction is problematic for the Hudson. A Nascar electric pump plumbed directly into all three freeze plug locations wasn't enough to cool the one I was familiar with.
Mark0 -
Have you considered reversing the flow?0
Just trying to get a little more flow. I raced a 308 powered Jet with a turbo. many years ago but it was a drag car only. Did not have a heating problem then.
This will be a road car and just wanted to know if another pump would fit and cool a little more.
Mark, do you have pictures of the Nascar pump set-up ? Thanks to all Rudy.0 -
Rudy,
I do not have pictures of the pump setup - but I know where you can find some. I sent you a message via Classicar messaging.
Mark0 -
Check with Steve at http://www.uncommonengineering.com0
If you are modifying engine, I presume you are using headers. 308 with headers should run at least 20 degrees cooler than with cast manifold.0
- 182 The Flathead Forum
