Road draft tube, vent tube
I need the tube that goes in the back valve cover. I know some call it a road draft tube, and some call it a crankcase vent tube. The one that was on the 262 that was in the car when I got it was gone. And the 308 I replaced it with did not have one either.
If anyone can help me with a tube for a 308, let me know.
Thanks
Mike
Thanks
Mike
I would put a grommet and PCV valve into the cover running a 3/8" hose to a vacume Line and switch to a Mopar Fill cap (with nipple), then run a 5/8" hose from cap nipple to bottom of one air filter .
I been using a Chevy V8 PCV valve set-up like this in all my Hudsons for yrs. It is especially nice when guides are a little worn by eliminating vapor over the fender at stop lights..
Just my opinion, but feel there may be some added engine longetivity by using a modern a PCV System....0 -
If you want to attempt the PCV installation, you'll have to determine how to properly meter what amounts to a calibrated vacuum leak. Then, you'll need a flame arrestor in the air cleaner to prevent a back-fire in the intake manifold from igniting explosive gases within the crankcase. Finally, and unless you want to create a James Bond smoke screen while you drive, you'll need a baffle before the PCV valve to encourage oil vapor to condense on it and stay out of the intake. Good luck.0
Tube With Mount Bracket And Hold In Bolt 30.00 Plus Shipping Here At Bill Albrights Vintage Coach, Good Luck, Bill Albright0
The other issue with a PCV system is that if you add a planned vaccum leak you will need to re calabrate the fuel mixture accordingly. My brother bought a 54 Hornet that had a PCV on it along with a fairly recent valve job. It had stainless exh valves. All of the exh valves were burnt, especially #6 which had a split to the center of the valve. I did another valve job & put the road draft tube back on. I would not mess with the factory setup unless you can figure out all of the modifications to make it work.0
Tube found. Thanks everybody.0
- 612 Vehicles
