Stepdown radiator support cushion???
Unknown
Is there a rubber cushion or rubber washer between the frame tab and the core (radiator) support on a stepdown?
    Yes Dave, there are two at each mounting bolt hole for a total of 8. The original isolators have inserts made of brass to keep them from collapsing when tightened.
  • Ken U-Tx wrote:
    .......Yes .
    Answers in time sync... scary...
    Hi Ken U
  • Hi Ken,
    I am referrring to the big center bolt that mounts the support to the chassis. Is there one there?
  • The one that goes here:
  • DaveFury wrote:
    Hi Ken,
    The Parts book does not call out a rubber pad for the radiator channel. I recall a single bolt through the channel assembly to which the radiator mounts. The parts book does call out a channel to bracket pad which is coded as required. My original comment about the 8 rubber grommets to isolate the radiator is my experience , but the book calls out 4 grommets one for each bracket and ferrules for each mounting bolt to keep the grommets from collapsing.
    Well, that explains why I can't find it! Thanks Ken.
  • Ol racer
    Ol racer Senior Contributor
    I just removed a core support from a 1951 and there were two (professionally) cut 3"x3" x aprx 3/8" rubber pcs (resembling a tire sidewall) on top of each other with a hole in the center for the bolt.
    Whether they are original or not is unknown.
  • I just pulled apart a 54 and found the same thing. A square of what looked like tire with hole through.
  • SuperDave
    SuperDave Senior Contributor
    Wether they are original or not is unknown.
    Everyone that I have taken apart had tire sidewall material as a cushion for the core support.
    Guess the as required material is the tire sidewall type cushion? I looked through my disassembly pictures, but could not find one to help you. Thanks to the others who knew what the as required was...
  • Thanks to all that responded. I took the sheet metal off some time ago, and wasn't sure if something isolated the two components. Sounds like a simple enough piece to make if the original does not turn up.
  • SuperDave
    Think of it as a shim. Since the front of the front fenders are hung on the core support. That cushion helps set the proper level to align the front clip.
