Heater fan question
Ken U-Tx wrote:Hello,
Yes there are 12 volt replacement fans available, take your old one and measure the mounting screw spacing and length, you should fit one with a shaft the same diameter, but the shaft will probably be just a bit too long, I simply cut the excess off with an air cutoff, or you could use a hacksaw, but be sure to deburr the cut end of the shaft before fitting the fan back over it. mine was a 4 Seasons motor, I lost the box with the part number on it. I did find the one I have by comparing my old motor to ones listed in the 4 Seasons catalogue. Hope this helps.
How about some contact information for 4 seasons. email, telephone number ect..
Thanks,0 -
There is a 12 volt motor that is almost correct, but the shaft diameter is 5/16 instead of 1/4. It's from a 1965 Ford F100 pickup. NAPA 6551020 or 4 seasons 35504.
http://www.4s.com/4sCat/CatalogSearch.aspx?action=GetPartSrch&part=35504&site=FourSeasons0 -
I have a rebuilt fan motor..never been used and if you are interested I'll
sell it to you for the price I paid.....$50.00 + shipping
Give me a call: 206 351-2649
Can have it to you in a couple of days0 -
re NAPA 6551020 heater motor are we sure this number is correct as i tried napa here today and no luck but they do have one for a
65 ford pick up
steve0 -
bartibog1 wrote:re NAPA 6551020 heater motor are we sure this number is correct as i tried napa here today and no luck but they do have one for a
65 ford pick up
steve
Well, according to NAPA's on-line catalog 6551020 is a good number and is for a '65 Ford F-100 pickup. May need to put BK in front of number. See link.
http://www.napaonline.com/NOLPPSE/(S(fx5xcy55barcdau5dn3atz45))/Detail.aspx?R=BK_6551020_01957130800
- 612 Vehicles
