Replacement for broken headlight switch?
I have a 1948 Super Six. It looks like the parking light and dash light circuits on my headlight switch don't work anymore. I have tested these circuits by unplugging the wires and hitting them with 12v, and the lights work. The headlight circuit itself works just fine.
Does anyone have a part number or year of a more modern car (assuming NAPA can't get the Hudson switch). I'm sure this headlight switch was made for several models over several years. It looks pretty basic. It's a 4 circuit switch, headlight, marker / tail lights, interior lights, and I don't know what. :-)
I've put relays in my car, so I suppose I could cheat and run all the lights off the relay (instead of just the headlights, as intended). That would mean in effect a single switch; all lights on or off.
Anyway, any ideas as to what I can do about this switch?
Thanks;
-Chris
Thanks;
-Chris
Chris, I replaced the headlight switch in my 51P years ago with a generic bubble-packaged item off a rack at the auto parts store, and it's worked fine. "hitting them with 12v"? I hope you had made the 12v conversion first!
Good hunting...0 -
You may be thinking about some of the older cars (and tractors) that had wierd stuff built into (or onto) the switch- like a fuse, or a resistor for hi-lo beam, etc. Generally, if the existing switch is just a box with terminals, a generic will work.0
That's right, generic will work fine and a little careful screening on said part, you can make knob and/or trim ring work along with the new switch.0
- 612 Vehicles
