Hornet Front Brake shoes
The only number you need is 440 293-4079. That's Dave Kostansek's phone number. Call him and you'll have the correct shoes in a couple of days. Let's support these long-time, reliable vendors of Hudson stuff.0
We Also Reline The No 18 Front Shoes, But Require Cores With Sales. Orig Cores Hard To Find, Bill Albrights Vintage Coach For You Hudson Owners West Of The Mississippi, Bill A.0
just out of curiosity what's wrong with the replacement shoes they sell? i have read the originals are the best, but what's the problem with the replacements? my local oreillys sells the replacements brakes best part # 55 i think. just wonder what problems do they cause. thanks, hr0
#55 is the aftermarket shoe number for the rear on step-downs. #18 is the correct aftermarket number for the front shoes. At a glance it looks very similar to the #263 shoe, but the radious cut-out at the top of the shoe is not positioned correctly to fit Hudson.
Jerry
53jetman0 -
Walt Mordenti had an article in a WTN several issues ago and it talked about how to use the 263 shoes. The entire proceedure of what to do. It is pretty simple,you are basically lowering the anchor pin down to accomodate the different configuration as Jetman 53 points out.0
53jetman wrote:#55 is the aftermarket shoe number for the rear on step-downs. #18 is the correct aftermarket number for the front shoes. At a glance it looks very similar to the #263 shoe, but the radious cut-out at the top of the shoe is not positioned correctly to fit Hudson.
Jerry
53jetman
#55 is also the correct number for Pacemaker Wasp 11"x 1 3/4"
J Spencer0 -
Clutch guy wrote:
Thanks clutch guy. Those that bought my tech tip books tell me after they set up those 263 shoes like I wrote they never had brakes that good. Walt.Walt Mordenti had an article in a WTN several issues ago and it talked about how to use the 263 shoes. The entire proceedure of what to do. It is pretty simple,you are basically lowering the anchor pin down to accomodate the different configuration as Jetman 53 points out.0 -
walt's garage-53 wrote:Thanks clutch guy. Those that bought my tech tip books tell me after they set up those 263 shoes like I wrote they never had brakes that good. Walt.
Walt,
Are your tech books still available?0 -
Kdancy wrote:
Yes, my tech tip books are available. They are in 2 volumes, number 1 and number 2. #1 is $20.00 and #2 is $15.00. If one is ordered it's $6.00 priority mail or if both ordered it is still $6.00 as both fits into the priority mail envelope. Walt Mordenti 45 Skyview Way San Francisco, CA. 94131-1248.Walt,
- 612 Vehicles
