How many Pickups in H.E.T. Club Roster
2
  • Lee ODell
    edited December 2013
    1921
    607336-Briggs, Leonard-Essex pu
    1923
    none-Markins, Richard- Hudson pu
    105261-Blake, Dr. Robert-Essex Truck
    1927
    186567-Blake, Dr. Robert-Hudson PU
    1928
    1HXA31AA1A3006604-Peterson, Edward L "Brownie"-Essex (Utah DMV vin #)
    1929
    11401-Johnson, Bob & Jeneane-Dover pu
    836795-Williams, Philip & Marcia-R truck
    1197827-Borkhuis, Ronald L.- Dover Screen Side PU
    1931
    A907041-essex truck
    1934
    403418-Kale, Press-Terraplane
    1935
    none-Fournier, Douglas B-Terraplane
    none-Whited, Michael & Tammy-Commercial Gu truck
    5130124-Dunevant, Terry-Terraplan G PU
    1936
    none-Heitkamp, Mike & Kathy-Terraplane
    none-White, Scott & Linda
    175307-Kellogg, Glen & Sally-Terraplane
    6143831-Ellis, Vern & Kristin-Terraplane
    6150803-Schwartz, Burton & Ann Marie-Terraplane
    6164808-DDDDDTodd, Mike & Tammy-Terraplane
    6167082 Douglas, Howard T. & Phillis
    CA567683-Lampe, David P.
  • Press's truck - 1934 - 403418. In 1934 Model K, Special and Commercial, serial numbers ran 373000 to 396725.
    There is no doubt that he has a 1934 model, but that serial number is an odd-ball.
    Alex Burr
    Memphis, TN
  • Lee ODell
    Thanks for pointing that out Alex. I thought it looked odd when I saw it in the Roster. Press and I are in the same club chapter. I'll give him a call about it. There are several numbers in the Roster that seem odd. I will correct any discrepencies in the list when I am given the correct Vin numbers. This is helping me to get aquainted with the HET vin numbering system. Your General Information handbook is a big help. I have not been familiar with pre 46 vin numbers, this project is helping and bewildering when a number seems odd.
    I was so blury eyed tired last night when I finished 1921-1946 list at 3:30 am. It was to long to post all of it at once. I forgot to click save it all before highlighting 1921-1936 and posting in smaller groups. When I went back to post the rest, 1937-1946 was gone. OOOHNOOO!!!! Went to bed. I'll redue and post later. The additional info posted on the forum will be included.
    Thanks to all of you for your help.
    Lee O'Dell
  • hudsontech
    Lee, I've spent nigh on 30 + years studying Hudson serial (vin) numbers and I'm still confused about it half the time. I discovered early on that there appears to be no (at this late date) one system. Starting numbers can vary from publication to publication - even within Hudson books. I've found plenty of sources; Hudson, Insurance blue books and so on - these blue books, such as Branhams and NAPA, are pretty much in agreement with Hudson sources, surprisingly. What I eventually ended up doing is going by this system - if I found 4 sources and could get two that agreed I'd go with that; if 3 sources agreed that was good; if all sources agreed (rare) we figured we were golden - at least until another source showed up. We have, I believe, one of the most accurate collection of numbers that are available given the lack of Hudson records.
    Alex Burr
    Memphis, TN
  • My 1940 Traveler was originally registered in Ontario, Canada, then California when I moved there. When I came to Santa Fe, the MVD clerk noted that the serial number on the door post did not match the Cali registration (the numbers were transposed). After telling me that I would have to get an affidavit showing that I owned the car, she just said "Oh, the heck with it" and changed the number back to match the car's manufacturer's plate. If you can show that the car was originally registered in 19** it's a 19**, whatever the serial number.
  • Mine is the 5130124 1935 G Same numbers on the firewall plate are also stamped on the front axle, passenger side and frame, passenger side.
  • dterry-2011 - If your curious about your serial number the first two digits (51) are the model (Model 51 or G - or you could say series 51, Model G). The remainder (30124) are the actual serial number.
    What this tells you is, breaking down the 51 is the 5 = 1935 and the 1 = Model G. The Model G's were offered in both Special and Commercial. Series 52 Terraplanes were Deluxe models. The other series were 53 thru 58 Hudson models.
    Alex Burr
    Memphis, TN
  • Alex, thanks for the breakdown-Doc you are correct, most people think that is a fire extinguisher. Happy Holidays.
  • Update on the 37 Doodlebug. No sign of a vin, but Jeff says it was built from a car. Everybody had these dual tranny things around here. People couldn't afford proper tractors. Dad built one from our 31 Model A, Model A front tranny, Ford truck 4 speed rear tranny and a worm drive Ruxtell rear end. Peeled the teeth off the brass worm pulling stumps with it. Uncle Elwin had one built from a 28 Dodge Brothers. There's a doodlebug club South of Oneonta, NY. If I ever get the coupe done, I want to build me one out of some of my Hudson parts. BTW, anybody figger out how we get 13 speeds out of a 3 and a 4 speed?
  • Uncle Josh
    I'll give it a shot.
    1st gear 1st trans
    1st first trans 1st second trans
    1 and 2nd
    1 and 3
    1 and 4th
    2nd and lst
    2 and 2
    2 and 3
    2 and 4
    3rd and 1st
    3 and 2nd
    3 and 3rd
    3 and 4th
    = 113
    Right?
    Lee O'Dell
  • Uncle Josh
    Well Lee, T1-1 and T2-N is not a speed as Rick points out. I suppose you could get 113 speeds by changing the motor revs. (I know, it's a typo)
    However, Rick, Double reverse doesn't go backward, it goes forward. T1-R reverses direction to backward, and T2-R reverses it back to forward. It's one of them imponderables. Gotcha.
  • dterry,
    If I may be picky, the "51" for thirty-five is part of the serial number, but, I believe, models had some other designation such as the G. When WWII came along, it's my theory that Hudson had the '43 line-up in the works and had assigned, on paper, the 31, 32 33, 34, 38 serial numbers for those vehicles but they were, of course, never made. Those numbers would have reflected the "3" in 43. When the war ended and production resumed, they maintained that serial numbering system, hence the 31 thru 38 s/n '46s. They couldn't use "60s" serial numbers for the model number in '46 since that had been used in '36, so they used 51 thru 58 as model numbers (the "5" in '45) while using the 31-38 for s/n.
    Similar dilemma for '47 (model 71+ had been used) except that they didn't have a good choice for s/n, so they added the "1" making them 170's. Problem solved for both s/n and model numbers for '47.
    The next year began the practice of using the last two digits of the year for Model/Serial # but that only worked until '51 when they were back in the "already used" arena, hence the change to the A Series and beyond (no relation to the 50A)
    That's my theory and I'm stickin' to it......'til proven wrong.
    Frank
    Josh, So two wrongs do make a right?
  • Frank-
    No, but apparently two steps back, does make one step forward!
  • hudsontech
    Frankvintagefullflowcom - you hit it right on the head. I think, also, that Hudson used the 3 in the serial number because that would have been 1943. Then to make life interesting they used a 5 to start the series numbers. Why they didn't just use either 3 or 5 who knows.
    The only year that I can come up with that used both numbers and letters was 1935 - thus the 5x for the model number and G (51) and GU (52) for Terraplane (GH (53),HT (54), HU (55), HHU (56), HTL (57), AND HUL(58) for Hudson models) for a series letter. And then there were the Canadian models - these used the letter "C" between the Model Number and the serial number (63-C-xxxx - except in 1935 when the C was used at the beginning (C-51-xxxx)
    Hudson did thing differently - they sure were different in a lot of ways.
    Alex Burr
    Memphis, TN
  • Rick, you got it! and a very good observation, Frank. In this case two wrongs do make a right.
  • The plot thickens a little
  • Frankvintagefullflowcom
    I believe I did explain why the 3 vs 5.....or at least tried to. A bit hard to follow but I've given it a lot of thought (like I've nothing else to think about). Avoiding the use of a previously used numbering sequence was the intent. Serial # is one thing, Model # is another in those days.
    The challenge to make sense of it came when I rebuilt a 32**** s/n 212 for our 172**** that came out of a 52**** model '46 Hudson....... Huh?
    I'm claiming victory 'til I'm proven wrong.
    Fimage
  • Lee ODell
    edited March 2014
    1937-1942 Hudson Pick Up vin numbers list
    1937
    no vin # - Jeff Green 37 Terraplane Doodlebug (Tractor)
    no vin # - Donaldson, J. B.
    no vin # - Polkus, Joe & Theresa
    no vin # - Albright, Barbqara A
    no vin # - Ramsey, Eugene & Frances - 70 truck
    no vin # - Heitkamp, Mike & Kathy
    no vin # - Dike-Smith, Daphne
    70580 - Smith, Conrad & Joan
    70673 - Lanning, Dave & Babe
    78393 - Smith, Conrad & Joan
    78514 - Cabot, Reverend John & Eleanor
    78539 - Gibbs, Robert & Heather Immel
    316029 - Buchanan, Calvin & Virginia
    701338 - Frock, Diane M.
    701613 - Falk, Ronald & Carroll
    701641 - Johnson, Glen & Maizie
    701714 - Bundy, Dale & Peg
    704463 - Norris, Mike & Pat
    705343 - Clarke, John
    706735 - Conrad, Larence G. & Marjorie
    1938
    no vin # - Schneider, Chuck
    no vin # - Jennings, Jerry & Judy
    8027481 - Dituri, David A. & Melba
    8847750 - Heitkamp, Mike & Kathy
    1939
    no vin # - Soneff, John & Beverly
    no vin # - Lathrop, Christopher & Carol
    no vin # - Clark, Richard & Sun
    904687 - Wible, James & Dawna
    9142233 - Walrath, Allen & Nancy
    9819711 - Quick, David J. & Patty
    1940
    no vin # - Ironhat, Julius
    no vin # - Smith, Val
    no vin # - England, Jack D. & Lory
    no vin @ - Fisher, Harlyn
    4744447 - Cooper, Dale W.
    4870585 - Smith, Bruce J & Doris
    4875573 - Nimtz, Ron - Elkto, Mich. Model 40
    1941
    no vin # - Reed, John & Kary
    no vin # - Spring, Perry & Kay
    no vin # - Eshelman, Gene & Myrna
    no vin # - Bruner, J.Richard
    no vin # - Thompson, Joseph W. & Robin
    no vin # - Kerchner, Keith & Sharon
    no vin # - Spring, Perry & Kay------------Pick Up Cab
    no vin # - Jack Heislers son -------------Not in roster
    no vin # - -----Not in roster-lwb- information presented by Dochubler-Wa. State
    310FOW15 - Schow, Lowell & Elizabeth
    47293 - Walker, James G & Gail
    1026385 - Hubler, Tim
    C1037598 - lG (Geo) - Not in roster
    1042120 - Arlt, Ernest & Faye
    C1050101 - ----Not in roster-swb- Information presented by DocHubler-Wa. State
    C1052543 - ----Not in roster-swb- information presented by DocHubler-Wa. State
    1056391 - Pontius, Lee & Carol
    1057530 - Smith, Val
    C1055879 - Glover, Don
    1081538 - Crowe, Steve D.
    1822005 - Goetz, Edward & Melrose
    1843536 - Hughes, Frank & Patricia============vin # listed twice
    1854833 - McKenzie, Larry & Bonnie
    1867601 - Clark, Ruthie & Will
    1875281 - Tom (12BoltTom)
    1869286 - Bird, Lew & Vicki
    1870861 - Hughes, Frank & Patricia=====correction one of 1843536
    1891174 - Countryman, Robert & Linda
    3871307 - Prie, George V.
    50211854 - Keister, David & Mieke
    1942
    no vin # - Wilcox, Joe
    no vin # - Amsk, Dave
    no vin # - Johnson, Cary Scott
    2015124 - Townsend, Grant & Jeanetta
    2023967 - Coleman, Stuart E. & Jeanne
  • hudsontech
    Frankvintagefullflowcom - not a problem with your numbers. As pointed out serial numbers started with a "3" (ie, 31, 32, 33, 34, 38) and model numbers started with a "5" (ie, 51, 52, 53, 54, 58) and fit as follows:
    Model 51 - Super 6;
    Model 52 - Commodore 6;
    Model 53 - Super 8;
    Model 54 - Commodore 8;
    Model 58 - Commercial (Pickup trucks, etc).
    I'm not sure why (does anybody know why Hudson did things the say they did??) but in 1947, retaining the same model lineup they started the model numbers with "17". Ok, the "7" stands for 1947, but who knows at this late date why the "1" in front. At least the model and serial numbers matched. Since 1948 model/serial numbers started with "48" one could ask why they didn't just use "47" (or "7") for the model/serial numbers in 1947. 'tis a puzzler", said the Grinch.
    Alex Burr
    Memphis, TN
  • The only answer to that Q that I can think of is that they'd been using the last digit of the year as the first digit in the Model/Serial no. for long enough they didn't know what to do. so they added the "1". You're right though, it would have been logical to have begun the last-two-digits-of-the-year format a year earlier. Did the '34 s/n begin with "4"? I'm too lazy to go look.
    Hmmmm. I wonder why the vin (1843536) is listed twice for our '41 pick-ups? We have two and I only have one s/n shown in my own list. I'm sure I submitted only the one for the roster.
    They both exist but one came with a title that doesn't quite match the truck.........Since the plan was to make one from the two, I didn't worry about the discrepancy figuring I'd just use the one that matches up. I'll go check the pillar tag.
    (Jeopardy theme music here)
    Ok, I'm back...did you miss me? The s/n of the other one is 1870861 so you may update your info to reflect that if you like.
    F
  • Add this to the 41's. I sent it to Uncle Josh and got no reply. Here is the s/n of my boy and I's BIG BOY 1941 truck 1875281
  • hudsontech
    Frankvintagefullflowcom - 1934 models didn't start with a 4. Using the year number started in 1935 with the number "5" as the first number. That continued until the 1940 models which started with a "4" (ie. 40, 41, 43, etc). They used the number "4" probably because otherwise they would have had to start with a "0".
    1941's, of course, started with a "1", 1942 started with a "2" and we know about the rest of the bunch.
    Another question might be if they ran with 480, 490 and 500 why did the 1951 models (thru 1954) use letters. Of course 1951 would have been 500 which was used in 1950 so that is probably the reason. Then 1952 would have been a 520 series, 1953 a 530 and 1954 would be 540. Perhaps the mind set was to get things a little simplified and go to the numercal/alpha system from 1951 thru 1954.
    Again who knows what Hudson's thinking was. They did a lot of things differently - the car keys for example. I'm not sure if it was all years, or just some, the ignition key was a round head and the door/trunk key was hex head. I think that's right. Everybody else did it the other way.
    This is what makes Hudson research fun. Oh, yeah!!!!!!! :((
    Alex Burr
    Memphis, TN :((
  • Ok, to beat it to death even further, they couldn't use 51, 52, 53, 54 as the first two digits since that had been used in '46 as model numbers. All '50s began with "50", it was just the Pacemaker that got to use the second "0". You knew that, I know.
    I didn't think the 4 had been used as the first digit in '34. I was just pretending to be dumb.
    How about pulling the lock knob upward to lock? Not a bad idea I guess as it's difficult to push it down with a wire. Like trying to stuff a wet noodle up a wildcat's.... uhhhh......nose.
    F
  • You also won't accidentaly lock your door by laying you arm on knob .
  • hudsontech
    Frankvintage - just to toss some more mud into the serial number listings the 1950 Pacemaker DeLuxe carried a model number of "50A". :D
    When it comes to researching Hudson serial numbers I sometimes think it would be easier to research something like, oh, Autocar or Octomobile or some such obscure make
    Hudsonly
    Alex Burr
    Memphis, TN
  • Don't forget the Henway.....I don't know that they had serial numbers at all.
    F
  • Frank,
    You'r just waiting for someone to ask huh... what's a Henway?
    John
  • hudsontech
    Rick, in the commercial body specifications list I have in the General Handbook (page 60, Table XI) the 1939 Model 91 Pacemaker Panel Delivery, body by Checker Cab, is listed. Checker also supplied the panel truck bodies for 1938 (88, 89) and 1940 (48).
    Alex Burr
    Memphis, TN
  • 12 Bolt, your truck is in my roster. I need name, contact condition etc however. Sorry I apparently didn't get back to you.
    If Lee's list is coming from the HET website, be aware that this is a work in process. My list is the membership list, modified by additions that are not yet in the roster or membership list, plus I retain old memberships.
    I can probably find you a truck in your area if you want one. People who have them, die or drop out and may no longer be interested, or have come to the realization that they are never going to get to finish it.
    BTW, Bruce Smith had just decided to sell his 40
    Also, that 39 Model 91 Pacemaker Panel with body by checker is 20 mi from me and is also for sale.
    HETcramerlp@roadrunner.com drop the HET of course
    HET commercial registrar
  • Lee ODell
    1946 Hudson PU Vin Numbers
    1946
    383761 - Porter, Stanley & Janice
    172470 - Hamson, Paul owner - Keister, David & Mieke previous owner
    17855845 - Myers, Frank & Mary
    17810108 - Vorse, Chuck & Carol=======1947 vin # listed as 46
    178134498 - Ellis, Vern & Kristin ========1947 vin # listed as 46
    no vin # - Bruce, George & Angela
    no vin # - Powell, Ed & Donna
    no vin # - Daigle, Larry
    no vin # - David, David & Marci
    no vin # - Hight, Byron
    no vin # - Schoemaker, Everett & Mona
    no vin # - Wilcox, Scott
    no vin # - Day, charles M. (Mike) & Peggy
    no vin # - Rose, Tom & mary
    no vin # =- Bogaard, charles J. & Donna E
    no vin # - Lathrop. Christopher & Carol
    no vin # - Boyd, George & Nancy
    no vin # - Welti, Jim & Pat
    no vin # - Lathriop, Christoper & Carol
    no vin# - Reeves, Glen & Deborah
    no vin # - Clark Richard & Sun -------178 model listed as 1946
    no vin # - Ypsilanti Automotive Museum
    no vin # Bogg, Ron & Linda
    no vin # - Dobson, Eldon
    no vin # - Serino, Joseph & Annetta
    no vin # - Ridenour, Richard
    no vin # - Stump, Perry & Molly
    no vin # - Erdman, Terry & Donna
    no vin # - Riggs, Richard & Phyllis
    no vin # - Maney, Chris
    no vin # - West, Charlie & Ann
    no vin # - Ramsey, Sam & Sandy
    no vin # - Johnson, Bob & Bobbie
    no vin # - cox, Tom & Tammy
    no vin # - Harmon, Roger B & Britt
    no vin # - Bowman, Randy & Jean
    no vin # - Haldemann, Al
    no vin # - Wandler, Jeff & Tammy
    H308601 - Simon, Gregory & Marily9698 - Smith, Benny W & Sandra
    38801 - Hudson, Tommy
    382477 - Undercofler, Carl & Joyce
    382932 = Allen, Fred & Jeannie
    383306 - Sollon. j. David & Mitzi
    384186 - Lawrence, dJohn H. & Lucy
    385273 - Miller, Todd & Sandra
    386085 - Dobson, Richard & Jacqueline
    386351 - McQueen, Kevin L. & Sharon
    3136720 - Grady, Jay M.
    3814186 - Burrow, Clovis & Joyce
    3814278 - Gibson, Gary & Di
    3814304 - Clarke, William H (Bill)
    3815134 - Welch, Stephen & Sally
    3815755 - Dabbs Robert & Rhoda
    3816385 - Jenkins, Gareth
    3818841 - Woodruff, Charles & Ok Ju
    3820465 - Wyman, Jack & Deloers
    3821451 - Karrar, Jeffrey & Sherel=========38 vin # listed as 1947
    3822010 - Wheeler, Norman & Bessie
    3822062 - Brewer, Alfred W. Edith
    3823485 - Cramer, Larry & Gail
    3823706 - Schneider, Chuck
    3B25053 - Chastain, Doyle & Carolyn
    3925352 - Brown, Jamres
    3825582 - Fleis, Larry & Marilyn
    3826845 - Wildrick, Doug & Terri
    3828761 - Goetz, Mike & Mary
    3828838 - Urcioli,Anthony
    3829873 - Denton, D. A. & Sandra & Drew
    3831931 - Cooper, Aaron K. & Kathryn
    3832624 - Bordwell, Kurt & Shirley
    3832999 - Ring, Dave
    3833711 - Buchenroth, Kerry & Kim
    3834741 - Thurman, Thomas & Michele
    3835080 - Brown, Daniel A
    3835157 - Hoyle, Bob & Ka ythy
    3837237 - Whidtacre, Donald & Jennie
    3837346 - Scott, Jack & Suzy
    3837505 - Pinder, Fred (Ric) & Alice
    3837661 - Porter, Stanley & Janice
    3844637 - Hughes, Frank & Patricia
    3845953 - Richter, Henry & Darlene
    3846004 - Tormohlen, Paul & Betty
    3846156 - Baroldi, Lance & Leanne
    3851321 - Whaley, Elmer & Betty
    3851536 - Kelly, Michael & Nadeen
    3852854 - Fleis,, Larry & Marilyn
    3853452 - Van Manen, Donald
    3854356 - Heckman, Alan E & Arlyce
    3857532 - Davis, Jeff & Donna
    3857609 - Bachtel, Warren L & Marlene A
    3860817 - Correllus, Dave & Judy
    3862396 - Philippon, Joseph J. & Liliane
    3863981 - Dobke, Marek & Joan DE Neve
    3865396 - Young, Robert M. & Donna Grant
    3871307 - Price, George V.
    3872422 - Babcock, Richard K & Joann Hosko
    3875038 - Griggith, Richard A. & Mary
    3875209 - Lorenz, Jr., Fred
    3876539 - jjnan58yahoo.com-----------not listed in roster
    3876589 - Efurd, Jr., Robert T. & Charlotte
    3877643 - Whitworth, Kirby L.
    3877812 - Albers, Delvin
    3878625 - Fluttrow, Warren
    3878678 - Harris, Charles J & Sharon
    3878698 - Hill, Larry & Hilda
    3886939 - Marshall, Robert W & Nanette
    3877493 - Tollison, La Verne
    3887755 - Doran, Alan
    3887875 - Kleen, James
    3888782 - Napiwocki, Thomas & Diane
    3889165 - Nimtz, Jeffrey R. & Melissa
    38373511 - Troost, Phil & Deb
    38122110 - Albers, Delvin
    58185577 - Harp, Gaylon & Esther
    501104479 - Schutte, Dr. Clair & Jackie
    586077299 - Goerges, Richard & Peg
