51 Hornet Project. With pictures.
You certainly jump into a project with both feet, that should be a fun ride. The most common statement from folks will probably be "I didn't know Hudson made a pickup".0
Looking good Preston!0
PaulButler said:Looking good Preston!
Very nice Preston, coming along very nice!0
Thank you Val, I am moving some parts cars right now, trying to beat the weather. I need my Hudson parts car out also, so I can take it to my shop at work. This will let me move to phase two of the project, (the drivetrain). I will also get to start working on the front bumper and grill as well.0
Brought the Hornet home to make room at work for the parts car.0
I bought this car to convert to 2 door club coupe, but when I got it stripped down I determined it would take to much work so I bought another body. At least the parts car has stayed in one piece, the club coupe broke in half when I unloaded it. I will be using parts from grill and bumper, as well as the entire drivetrain. I have been anxious to start on the engine, it's what attracted me to a Hudson in the first place. Here is a couple of pics of the parts, and the rust that condemned this car to parts car status.0
Need to evict the rodent living in heaven on top of that engine.0
Oldfarmer1947gmailcom said:Need to evict the rodent living in heaven on top of that engine.
I moved the car just before that picture was taken, he hasn't been back so I guess he's looking for a new home now.0 -
Worked on the parts car today. As previously mentioned I will be using engine trans and rear end. I've seen cars turned over to remove rear ends, thought I would give it a try.0
Parts car? What parts car----:)0
Kdancy said:Parts car? What parts car----:)
I am very excited about starting on this engine, today I pulled it out. I need to get the front frame ready for storage, then I can dismantle the engine to see what will need to be done.0
You my friend have a lot of work ahead of you with that one but after seeing what you have done with the others I have no doubt you can do it. Rock on!!!0
I forgot to take pictures today, I'll try to remember to get some next week. My workbench hasn't been this busy since I started on the body almost 4 years ago. I am actually about a year over budget for the body work, but I have decided not to do a full interior, so that makes up the difference for me. I had originally planned on a year for the interior but I don't think the car will recoup that kind of investment. I will continue to get it running and driving and enjoy it the best that I can. Here's a couple of pics from earlier in the week that didn't come out the best, but will give a good idea of my winter work schedule. Hope everyone has enjoyed the build so far, thanks again to all who posted their support for the project, it really helps to keep me motivated.0
Crazy Kool to participate from the forum sidelines !0
Working on cleaning parts, and getting parts ready for storage. Made a little progress this last week, but dragging my feet some on the engine until after the holidays. I don't want to have the engine all dismantled and waiting for parts. I need to buy a service manual for engine repair. I'm unsure about a head bolt removal sequence.0
The Hudson manual for engine disassembly does not have a removal sequence. The re installation is specified in the manual. Links to the Hudson Manual required for your mechanical activities are part of my website. http://hudsonrestoration1948-54.com/
Merry Christmas to you0 -
Are you installing a 232 engine in a Hornet?0
Oldfarmer1947gmailcom said:The Hudson manual for engine disassembly does not have a removal sequence. The re installation is specified in the manual. Links to the Hudson Manual required for your mechanical activities are part of my website. http://hudsonrestoration1948-54.com/
Ken, Thanks for the info, GREAT WEBSITE!. I will be visiting it more in the new year. Merry Christmas to you as well.0 -
lostmind said:Are you installing a 232 engine in a Hornet?
Yes sir. I am installing the 232 in the Hornet, and I might even take it over to the local race track and run it through its paces, during the H.A.M.B. drag nationals. I don't expect to live up to the Hornet's legendary record, but it will be a lot cheaper to drive it. I plan on using the car for photo opportunity's on Route 66 at some of the events in the Joplin MO. area, and to just enjoy the ride of a 50's era car.
Keep at it and you will have a nice car. I know this old kan o tex station as I have visited it many times. I too use my 39 for photo ops along US 66 around Stl and thru ILL. Merry Christmas Trimman Looking forward to more photos as you progress0
Val, Thanks for comment, I am always on the lookout for Hudson's in my area hope to see you and the 39 sometime. Merry Christmas.
Pulled the head off today, engine has no rust in the cylinders whatsoever. Pistons are extremely clean, only a slight trace of carbon buildup. May have been overhauled shortly before being parked? The rear end had new brakes and hardware installed, and the receipt for the tires showed only around 8oo miles since new.0
I think I may have found out what caused this car to be parked way back when. It looks like all the cork material is spun out to the edge of the pressure plate. Is this common when the clutch goes out?0
Seen that condition before.... I believe it is called SLIP SLIP SLIP... NO MOVE0
Yes Sir!!!! Oldfarmer is a 100% correct. Had mine replaced and didn't look near that bad. Wildrick can rebuild it for you if you are unfamiliar with it.0
Val said:Yes Sir!!!! Oldfarmer is a 100% correct. Had mine replaced and didn't look near that bad. Wildrick can rebuild it for you if you are unfamiliar with it.
I am trying to decide between the 3 speed manual or the Hydramatic. It will probably come down to the availability of a shifter cable for the single lever manual.0
- 86 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
